Dioda LED miga w sposób ciągły
chuckcrowley
Czytelnik
Czytelnik
Post autor: chuckcrowley »
What's So Good About The Popular Shark NV360 Upright Vacuum
Shark Navigator Lift-Away Deluxe NV360 is indeed one of the most well-known vacuums from Shark. This upright has constantly been on many [Link jest zablokowany dla Gości. Zaloguj się!], where it has earned compliments from customers and reviewers. But what makes it so popular? Let's find out now.
The Biggest Benefits of Shark NV360
You don't need to spend big.
The NV360 is among the most affordable vacuums you can buy from Shark. It costs much less than higher-end upright series like Shark Rotator, Dyson Ball, Bissell Crosswave, and Oreck Magnesium. You can save plenty of money, up to three hundred dollars, when opting for this inexpensive upright. Despite its price tag, the build quality of NV360 doesn’t feel that cheap at all. It's one of the most solid vacuums you can get at this price point.
Obrazek
You can turn on/off the brushroll.
There is a switch of the brushroll on the NV360, right above the canister. You can use it to turn on the brushroll while vacuuming carpets and turn it off when you're running over a delicate surface like hardwood. This helps users avoid scatter by stopping the brushroll from spinning and damaging the surface.
You can convert it to a portable unit.
With the trademark Lift-Away feature, the [Link jest zablokowany dla Gości. Zaloguj się!] allows users to use the wand, hose, and tools with one hand while carrying the canister-motor assembly in the other hand. In this mode, it works like a corded handheld vacuum, making it easier for you to reach places not accessible to a traditional upright, such as your car's interior or stairways of your house.
You can store tools onboard.
You can store both two attachments provided by Shark onboard using the handy clip. This seems to be just a small detail, but it makes all the difference when you suddenly need one specific tool but doesn't remember where you have stored it. With the NV360, the tools never get lost and can be fetched right away.
You can adjust the suction.
The NV360 comes with a release slider for suction power, which is really a simple mechanism to turn up or turn down suction. There are many situations in which the ability to bleed off suction can come in handy. For example, you may find it difficult to move a vacuum around as there is too much suction between the cleaner head and the surface. Reducing the suction can overcome this small issue. In a similar fashion, when you are cleaning something delicate, you may wish to have a smaller suction to make sure there is no damage done to the surfaces.
Obrazek
You can use it on most kinds of surfaces.
We have run this Shark vacuum through its paces, and the results were quite impressive in most cases. This upright did a great job of picking both small and medium debris on low-pile carpets and bare floors.
Conclusion
The [Link jest zablokowany dla Gości. Zaloguj się!] might not be the most powerful vacuum or the model with the most attachments. But it's a reliable machine that works great in many situations. It also comes with many features found on high-end models, and the best thing about this machine is you don't need to spend much money on it to benefit from those awesome features.
